could be a defective handlebar switch. I would start by disconnecting the swith and see if the problem stopscould be a defective handlebar switch. I would start by disconnecting the swith and see if the problem stops
You can't post conmments that contain an email address.
FIPS are 5 digit codes..the 1st two codes are for the state: the last three are for the county. This link allows you to find both state and county for your area: http://www.epa.gov/enviro/html/codes/state.html
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
There's nothing you can do. With the switch to digital broadcasting, the sound isn't on the same frequencies it used to be so this radio can't pick it up. Right now, nobody's offering a digital receiver for the sound. All your radio is good for now is the regular radio and weather broadcasts.
