Kenmore Elite 45986 Front Load Washer Logo
Anonymous Posted on Nov 08, 2009
FDL fault code on kenmore elite washer
Kenmore washer fault code FDL. Wont fill with water.
Anonymous
Level 3:
President:
  • Master 2,049 Answers
  • Posted on Nov 08, 2009
Anonymous
Master
Level 3:
President:
Answers
2049
Questions
0
Helped
1489608
Points
8420
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Testimonial: "Very quick answer.......even better was it solved the problem. Thanks"
mikadot
Level 3:
  • Master 2,113 Answers
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
466236
Points
5959
FDL i am assuming is Faulty Door Lock   close the door a few times   make sure there is no obstructions  if all else fails check the micro switch in the door latch area for failure or broken plastic that supports it
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
What is code FDL
FDL code is a door lock code on these washers, but be advised, the older models had an issue with the main control boards loosing connection at the soldered joints for the door switch. They would loose solder, and the board would think the fault was the door lock and it was actually the board.
1helpful
GIVING CODE FDL?
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Fault code fh
F/H code means the machine has not detected water entering machine. If the machine is filling with water then you need to check the pressure switch. If no water is entering machine then you need to check the fill valve.
2helpful
Hello! My Kenmore washer door will not open. It's completely locked and will not budge no matter what I've tried. I have a load of cloths in there as well. When I turned the power on detergent and cloths...
Unplug the washer for AT LEAST 30 minutes to reset the Central Control Unit (CCU). If the door still remains locked after a CCU reset, you can still open the door by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
NOTE: The "Fdl" and Fdu" fault codes are for older models of your washer, but the principle of accessing and releasing the door latch is still the same.
If your error code still persists, you may have to replace the door latch. Just follow the guidance in the link below:
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
6helpful
Kenmore Elite HE4t Washer
Remove three screws in the back that secure the top. Push down on lid and slide to the back.
2answers
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Alexander
vince
