It sounds like you have a problem with the air temperature sensor on the roof. either you have some damage to the wiring going to the sensor, or the sensor itself has gone bad. Also, check the wiring inside the control box, make sure the connections are tight. If possible, follow the wire from the control box all the way to the sensor. If the wire looks good and there is no damage at all, the sensor probably needs to be replaced.
