My kodak dpf800 digital picture frame will not recognize my 4GB SD card. It says please insert card even though it is in the slot. I previously was using a 256MB flash drive and it worked fine.
SOURCE: Hi, I purchased 3 Coby digital
Good day,
I read up on the specs of the frame and it does not have an internal memory, thus you will have to have the sd card inserted at all times to display photos.
Hope this helps!
Regards
SOURCE: Cannot locate info. on what SD Cards I can use in my Kodak CD40
According to the specifications, there is no flash memory card slot in this model. The only way to transfer pictures is via serial cable to your computer.
SOURCE: I have a Kodak SD card for my digital camera. It
well it does not mean for sure the card is bad, but a sign. If you have a computer you can plug it into you might be able to reformat the sd card. other wise you will have to get a new one since fixing a sd cards hardware is close to impossible. but good thing these cards are cheap and you can get them for $10 on Newwegg.com
Testimonial: "I was more than pleased to receive an answer to my problem within minutes of posting! The answer was helpful to a degree and very easy to understand."
SOURCE: Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: digital picture frame does not work after being charged overnight
I returned the product and exchanged it for one that worked in the store.
