I have a Eureka Contour Bagged Upright vacuum that is a couple of years old. Just recently it lost suction. When using the accessories/attachments, however, this is plenty of suction power. I've changed the bag, filters and cleared the brush of hair, etc. I've also checked for any obstructions and have found none. I'm wondering if the belt needs replacing as the brush makes an unusual pattern on the carpet. The vacuum was a gift and I did not receive the manual. Thanks
It is simply your belt - replace it.
The suction you said is fine with attachments, so the belt is not turning the carpet brush
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
It was the belt - just need replacing, which I did.
Thanks anyway.
