First time i used the 400 watt inverter i plugged it into the cig lighter and then plugged a 1500 watt food dehydrator into it, and the inverter instantly turned off. I checked the fuses on the inverter and they're fine. I also checked the fuses on the cig lighters and the voltage in the cig lighter coming from the inverter power cord: 0.015 volts which seems low but it worked the first time and it worked for the other inverter that i had through my job. plus, the vec1024 works fine when i connect it directly to the battery - but when i plug into the cig lighters nothing happens- no lights, doesn't turn on.
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
