Received this 6011 machine 8 years ago and have never used it. No manual... How do I thread it, fill bobbin and do basic straight stitch... I'll start there (:
Unfortunately, I couldn't find a specific manual for the Dial and Sew 750 sewing machine. However, I can give you some general instructions on how to use a sewing machine that may help you get started:
Threading the machine: Follow the threading guide and thread the machine correctly. Make sure that the presser foot is raised when threading the machine so that the thread can be properly tensioned.
Winding the bobbin: Place the thread spool on the spool pin and wind the thread onto the bobbin by following the instructions in your manual. Make sure to cut the thread once it's wound.
Installing the bobbin: Open the bobbin case and place the bobbin inside it, making sure the thread is coming off the bobbin in the correct direction. Then, pull the thread through the slit in the bobbin case and hold onto it.
Adjusting the stitch length and width: Depending on the fabric you're working with, you may need to adjust the stitch length and width. The stitch length controls how far apart each stitch is, while the stitch width controls the width of the stitch. The controls for adjusting these settings will be on your machine, typically on the front or side of the machine.
Sewing a straight stitch: Practice sewing a straight stitch by lining up the fabric with the edge of the presser foot and slowly pressing the foot pedal. Keep your hands on the fabric, guiding it through the machine. Be sure to sew at a consistent speed to maintain even stitches.
Using additional stitches: Many machines have a variety of stitches you can choose from. Consult your manual to learn how to select different stitches and adjust the length and width settings.
Finishing your sewing: Once you've finished sewing, cut the threads and remove the fabric from the machine. You may also need to clean the machine and oil it, depending on the manufacturer's recommendations.
Remember to always consult your manual for specific instructions on how to use your particular machine. Good luck with your new sewing machine!
Be sure to pull at least 4 to 6 inches of thread through the needle's eye before beginning to sew. Pull the bobbin thread up to the top of the fabric BEFORE beginning to sew.
Then, BEFORE taking the first stitch, hold both thread tails with the left hand and then slowly begin stitching. After a couple of stitches, let go of the thread tails and continue to sew.
If you need instructions on how to thread your machine, search the internet for a manual:
Make + Model + the word "Manual"
or look for videos on YouTube to help with the threading process.
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
? 6:55 https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
aside from cleaning, with a thread bunching problem it's always good to change the needle and make sure the top thread has not come off the thread take up lever and make sure the bobbin is turned the correct way in the bobbin case. as for the zig zag stitches, it sounds like a gear or cam could be damaged or worn. if someone brought me a sewing machine with the same problem, the first thing I would check for is a damaged or worn gear..
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop is the fabric & thread & needle compatable with each other? did you use every thread guide when threading the machine? is the bobbin in correctly? is the bobbin warped?
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
If your machine has been stored for 5 years, you should give it a good clean and oil according to the manual before you do anything else. Then put in a new needle and wind a fresh bobbin, checking that the bobbin has been wound smoothly as a badly wound bobbin can cause poor tension and stitching from the bottom thread.
You want the thread to go from the spool through a tension disc or eyelet to the bobbin and keep some gentle tension onto the thread spool using your scissors handle or similar so that the thread winds off it smoothly and the spool doesn't bounce around. Also give the thread a nudge with your finger tip as it winds onto the bobbin so it fills evenly, top, middle and bottom, not all in the middle.
Are you wanting a straight stitch to sew around the hemline? If so, your stitch length is right, but stitch width should be zero. You don't say what knob is set to 4, if its your top tension then that should be close, usually between 4 and 6 if dial goes from zero to 10.
Which thread is too tight? top or bottom. Firstly check the threading path to ensure that the top thread isn't catching on anything, is through the take up lever properly and coming from the thread spool without catching there. Some thread spools have a little knick in the top where you can catch the thread to store it, but you dont' want the thread to catch here when seaming, so turn it around the other way on the spool so it can't.
Try test stitching a medium zig zag stitch on scrap fabric, and you'll be able to see if the bottom thread is pulling in or the top one, then adjust the tension dial a little to lessen this.
Hope these pointers help, if you can't get a good neat stitch after trying these things, then consider taking it for a clean and service, the technician can get inside and clean the machine thoroughly and also check for any other issues that might be there.
If your stitches do not look good on the top side you have a problem with the bottom thread. make sure you have the correct bottom tension: Is the thread under the bobbin tension plate and when you hold the bobbin and case lightly in your hand the tension should be set in a way that there is little resistance , yet still some, when you pull the thread. After you set your bobbin tension, you may have to adjust your top tension to balance. Also make sure the thread comes off of your bobbin the way your manual tells you, clock or counter clock wise.
Make sure your bobbin (plastic) is not sooooo old, buy a new one.
