SOURCE: Trouble removing the seal nut and the long screw that hold that bottom agitator
If your machine has the plastic nut, I use a pair of channel lock pliers to remove it. It usually will break but you will need to replace it any way. To get the basket support off, I use a piece of flat steel and large hammer. This will need to be replaced also. The new basket support has a seal in it that takes the place of the plastic nut.
I assume you are replacing the bearing and seal since the bearing wearing is usually what causes the seal to leak.
Post back if you have any questions.
Thanks/Mike
The inside of the agitator tube is disgusting- I want to clean it out. How do you remove the agitator or how do you remove the buildup of crud without removing it?
