Ok ...the NVC files are the extentions from the nerovision and you will need this program to see it ....so ...install the program in the new computer ...if there is already installed..just make the file association ..by right click ...than open ..and choose the program by browsing ......
or...right click on the file...than properties...than ...you will see the file type ...and under ..."opens with" ...in the right its an change button ...click on it and browse the programs for the Nerovision ...Choose it ...than click aply ..and ok ....
after that on double click the files will open with the right program ...
in short ...Nero will do it...and next time use windows movie maker...it will save in avi format ...and you can do anything you want even add music on it ,,and transitions...
after opening ..try to see if it has any more posibilities to save in another format ...or ...burn it on a disk ....or use a converter to like ( anyconverter ) to make it in another format that will be openable in a more common program ...
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
this may vary depending on your operating system
Hope this helps.
