Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
First, connect the TV to the Playstation using the an HDMI cable.
Then, turn off the TV and turn it ON after turning on the Playstation.
Make sure that you've selected the correct input on the TV that corresponds to the input port on the TV to which the PS3 is connected.
You can select the input on the TV by using the TV remote.
Once the TV and PS3 are connected properly and correct input is selected on the TV, the TV should receive the video signal.
Any signal transmitted from PS3 in 720p, 1080i or 1080p is a high definition signal.
connected tv to ps3 in component 1, turned tv off and the back on and still lines on the screen, definetely not hd clear
the picture onscreen is full of lines when connected to my ps3.i am using monster hdmi cables to connect to my samsung hln467w.a comcast box has been hooked up and the picture is good but other things hooked up to the tv have lines and are harder to see
