D3drm.dll errors usually appear when a game or other software program is started.
D3drm.dll issues are caused in one way or another by an issue with Microsoft DirectX.
The d3drm.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3drm.dll errors usually show up only when using these programs.
Important Note: Do not download the d3drm.dll DLL file individually from any "DLL download site."
1. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3drm.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
2. Assuming the latest DirectX version from Microsoft doesn't fix the d3drm.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
3. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with d3drm.dll and a reinstall could do the trick.
4. Restore the d3drm.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your d3drm.dll error, try extracting the d3drm.dll individually from the DirectX downloadable package.
5. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Go to the following site, copy the d3drm.dll and save it to your c:\windows\system32 folder
SOURCE: d3drm.dll
This graphics driver is not included in Vista. In order to get it to work follow these steps:
1) Download "d3drm.dll" from http://www.dlldump.com/download-dll-files_new.php/dllfiles/D/d3drm.dll/5.1.2600.0/download.html
2) Copy it in to the "c:\windows\system32" folder
Run your program again and it should work.
SOURCE: d3drm.dll its not working on my pc
D3DRM.DLL is Direct3D Retained Mode, a very old technology from 1997 that
was removed from Windows Vista. Almost no applications use it, but it sounds
like the one you are trying does.
I'd say go to the Microsoft website and download the direct X runtime
updates
http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71...1b-bc6a
This is not the same as installing or re-installing DX 9.0c.
I did a search on my system and my XP install does have the D3DRM.DLL file,
but my vista install, in which I did install all of the DX updates, does not.
Is the game you are trying to install fairly old ?
If you have another computer system with XP on it, you could search for
that file, Should be in the c:\windows\system32\ folder and copy that file to
your vista system to the same C:\windows\system32 location
If not,you can download the file from this location. downloading from an
unknown site is always a bit risky, so I'd suggest finding someone with an
XP install and using the file. but this will get you where you are going. I
did a file compare to the one I had and the one listed in the link, so it
appears to be the same file.
http://www.dlldump.com/download-dll-files_new.php/dllfiles/D/d3drm.dll...1.2600.
Hope this would help you a lot.
Please rate me if i am helpful.
Thank you.
Yboyandrei
