Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
Posted on Nov 06, 2009
Just set up my iomega select to my mac os x 10.3.5 instructions say, re format the drive, so I go to utilities click on disk utility but nothing happens except greyed out icon, I cant format anything. I thought it was meant to be simple?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
278
Points
I'm having almost the exact same problem. Did you manage to solve yours?
I don't know how to select the type of partition needed for my mac when I am formatting the drive for mac OS?
1 - Place the drive on the desktop.
2 - Start the "Disk Utility." Click on the drive, then on the "Erase" button.
3 - Select the "MS-DOS File System" in "Volume Format."
4 - Provide a new name for the drive. Click the "Erase" button.
5 - Perform the instructions given on the screen and finish the formatting.
tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 • Computers & Internet
1helpful
How do I reformat my Iomega eGo hard drive so that it is compatible with my Mac? OSX 10.6.6 The current IOmega format is FAT
First of all, connect the Iomega to you mac, make sure it powers up and is detected by the Mac. Now follow these steps: ( It's important to note the Drive before you begin this task so that you may not make any mistakes.)
  • Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
  • Select the disk that needs to be formatted on the left.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to your Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
My laptop does not recognize my iomega hard drive
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Hello, my Iomega 34579 1 TB USB 20 Hard Drive was working ok in my MAC but I've plugged it into my pc and it does'nt work, what do I have to do?
You probably formatted it as HFS+ to work with your Mac. Windows cannot do anything with that format. If you are wanting to use the drive with both Windows and Mac, you are going to have to format the drive as FAT32. There is a 4GB per file size limitation with FAT32. Otherwise there isn't anything that you can do.
To format your drive as FAT32 with a Mac OS X, Version 10.4 and above:
1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility
In the left hand column, click on the drive icon for the Iomega drive or disk.
Make sure you click on the high level orange drive icon, not the second level volume icon.
3. Select the Partition tab. 4. Change Volume Scheme from Current to 1 Partition. 5. Click on the Options button. 6. Select Master Boot Record as the partition type. 7. Click the Format drop-down menu and select MS-DOS File System as the format type. 8. Click OK. 9. Click the Partition button
2helpful
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
2helpful
I just purchased an iomega ego /500gb and I'm having a problem formatting it by following their instructions. I just want to be able to plug it in and save my music. My mac doesn't even recognize it once...
You will need to format the drive to work with you Mac.
NOTE: For devices with 2 or more hard drives, please review the configuration settings to determine which volume type works best for you.
9. Click OK.
Trying to find manuals how to use the iomega with my apple mac but are not sure which one i have. On the hard-drive it says iomega with an i above it.
Manuals are not the easiest to come by for Iomega hard drives, but I can certainly assist you with formatting your hard drive for your Mac
All you need to do is this:
font.f1 {font: 14.0px Times}  * From your desktop click anywhere on a blank space on your desktop.
*Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the drop-down menu. This will take you to your Utilities folder.
* Locate and launch the Disk Utility application
* Once Disk Utility is open, with your Iomega drive hooked up to your Mac and turned on, look in the left side bar and you should see your hard drive.
* Click on the hard drive and this will make the right window available to you.
* Now click the Partition tab
* It is here that can change your volume scheme from Current to 1 partition (or more).
* Once you have done that make sure to give your hard drive a name.
* Under Format: Make sure to select "Mac OS Extended(Journaled) format (this is the readable format for a hard drive being used on Macs).
* Once you are satisfied that the partition(s) is configured to your liking, the click Options button.
* Select GUID Partition Table for Bootability on an Intel Mac computer or notebook
*or select Apple Partition Map for a Power PC based Mac computer or notebook.
• Click Ok for that selection
• Click the Partition button and your drive will be ready to use once the format completes.
This should do the trick. Let me know if it works for you.
Thanks!
-Mactechtrainer
2helpful
1T external will not mount on Mac OSX. It worked fine but just stopped. Have tried other computers and cables but nothing. It is getting power. Model #MDHD10T-U2 Serial #JPA7470874
This needs to be formatted before it can be used on a Mac.
  1. Launch Disk Utility by selecting ApplicationsUtilitiesDisk Utilities
  2. Click on the active partition to select it.
  3. Click on the Erase tab.
  4. Select MS-DOS (FAT) from the Volume Format drop-down menu.
  5. Click on the Erase button.
  6. When Disk Utility is finished erasing the disk, click on the active partition and ensure that the Format field at the bottom of the Disk Utility window says that the volume is MS-DOS (FAT32).
  7. You can now quit Disk Utility.
108helpful
2answers
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
