Yes...yoou have two totally difference applications your ver. more advance than the home edition that does not have one...sorry
Hold down the windows key and press r on both computers, type winver and press ok.
do that on both computers,
send me the results from both.
What I need is what it says at the center - top of the window - Windows 7 XXXXX
Then
Version x.x (Build xxxx)
I don't need any of the rest.
For Windows XP:
Open the problematic folder, Press and hold SHIFT key, right-click in empty area and select "View -> Thumbnails". It'll toggle the file/folder names.
Actually its a feature to show/hide file names while in Thumbnails mode.
For Windows Vista and 7: Open the problematic folder, right-click in empty area and de-select "View -> Hide File names". If the option is not available, then press and hold SHIFT key, right-click in empty area and select "View -> Medium Icons".
Speed Up Windows 7 Boot
Full Image
Speed up Windows 7: Change Taskbar Thumbnail Preview Time1. Click on Start, enter "regedit" into the search field.
2. Goto: HKEY_CURRENT_USER\Control Panel\Mouse
Speed Up Windows 7 Taskbar Thumbnail Preview
3. Double-click on "MouseHoverTime" and change the value to 100 or lower:
Change the mouse hover time to 100 or lower
4. Voilà, your thumbnail previews should appear a lot faster now. For another great tweak to speed up the Windows 7 taskbar, click here.
Speed Up Windows 7 Shutdown Time1. Open the registry editor (enter regedit into search field)
2. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control"
3. Lower the value (12000 is the default value = 12 seconds) to a value of your choice
Speed Up Application Access - Increase your productivityFirst of all create a folder "QuickStart" somewhere on your PC. Right-click on your taskbar:
Locate the folder "QuickStart" (you just created the folder so yo should know where it is) and then click "Ok". You are almost done, but we don't want that ugly text on our taskbar that is using a lot of space, turn it off:
Right-click on the new toolbar and uncheck "Show Text" and "Show Title"! Now drag the toolbar to the left until it's below the main icons and you will have something like this:
Hello and thank you for your help!
They both say: 6.1 Build 7600.
His is Windows 7 Home Premium and mine is Windows 7 professional.
Also - I am late responding to you because Fixya seems to have stopped sending me emails to notify me when a solution has been posted - so I went back to my question by chance. Do you know how I can get the email notifications back?!
