My CPU is started booting only when I press and hold the power button. It was normally starting booting once I press the power button. What may be the problem. Kindly show me some solution for this
Hard reset it so it`s data and all passwords will be removed for this please follow the below steps (most Common)
If your phone is on, power it off.
Hold down the Power and Volume down buttons. Instead of booting up normally, you'll see "Start" in an arrow pointed at the power button. Here you use the Volume buttons to scroll and the Power button to select an option.
Press the Volume down button until you've highlighted Recovery mode.
Press the Power Button to start recovery mode.
When your phone reloads, you should see a screen that says "No command" with an Android robot in distress. Press and hold the power and volume up buttons together to load the recovery mode.
Using the Volume buttons to scroll through the menu, highlight Wipe data/factory reset.
Press the Power button to select.
Highlight and select Yes to confirm the reset.
Once the reset is complete, you will be bounced back to the same recovery mode menu. Press the Power button to select Reboot system now.
For Network Unlocking contact to best unlock code provider below
1. Power down the printer
2. Press and hold the lower left hand corner of the screen
a. This is normally where the progress bar starts loading on the screen
3. Power on the printer
4. Release the left hand corner once the "Permanent Storage Init" message appears.
or alterative way
2. Press and hold the right arrow button on the navigational bar
a. This button will flash for a moment when the printer boots up
Hold down the power button until the computer shuts off. The press the button to restart and see what happens. There are several different ways to startup. immediately upon hearing the boot tone, press and hold the shift key to boot in safemode. If this fails as well, then you will need to boot with the install CD. This is done by immediately pressing holding the C key upon powerup
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
I think you have to shut your computer down completely and reboot. This means that you will lose any work you didn't save before going in standby mode.
If your PC has a 'reset' button (usually located near the power button), press it. Your machine should reboot. If it doesn't or if you don't have one, you can try pressing and holding the power button for about 5 seconds. This should shut down your computer completely. Press the power button once more and it should boot normally, though you might get a warning saying Windows didn't shut down properly. If you get the choice, just choose to boot Windows normally.
If pressing and holding the power button doesn't work, try looking for a power switch on the back of your machine. It should be near the power cable. Flip the switch, wait a few seconds and flip it again, then boot your computer as usual. You might get the same message which I mentioned above.
I would try to boot up in safe mode, then download glary utilities which is a free registry cleaner. Also doing a windows update would also be a good idea.
you may want to reinstall your operating system i know several people with this issue and it has worked fine just insert the cd of whatever os you choose then boot from it
Ok, your psp CPU clock speed is set to low speed.. 2 way to change:
1. If your psp has VSH menu enable.. : press "select" button, a small window will appear, otherwise its set to "disable".. See at "CPU CLOCK XMB" must set as "default". use left-right d-pad to change it. if vsh menu is disable you can try 2nd way.
2. Boot PSP under Recovery menu ( Hold R-trigger when turn on your psp ).. under M33 menu select "CPU Speed" then press "X", select "Speed in XMB" and "Speed in UMD" to setting as "Default" by pressing "X" button a few times.
Hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
