You can fix this by removing first removing all power, then remove
the plastic cover above the keyboard,
removing removing the two keyboard screws. You'll need to fold the
keyboard in such a way that you don't damage the cable. You will see the wifi
card just to the right. It's the only card there. It is held in place
by spring clips. Remove the card from the connector. There are two
solder contact points labeled "C88". Connect the power adapter to the
laptop now. Short the two contact of "C88" and press the power on
button. The unit should boot to the windows screen. Once it boots,
you'll have to update to the latest BIOS.
somebody set the bios password to reset the bios password open the back cover of ram u see a small battry like a coin remove it fo10 to 20 second and remove laptop battry at same time then plug the adapter u will see baios was reset if u have any qury plz tell me the laptop model no and manufacturer
I think it came with a 512M on a 533 mhz bus speed (ddr2) and it supports up to 2G DDr2 on 533 ..Pay attention on the bus speed if you want to upgrade...and not insert anything else but 533 mhz cause you may experience problems with it ...I suggest not to use teh maximum either ..but if you have already a 512 M in one slot ...just buy and use another 1H module in the other slot ..and will be working great ..even on windows & ..which require at least 1G of ram .. Good luck ! ..and please rate my answer ...
Resetting a Toshiba BIOS Password
KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptops can be convinced to boot without their power-on
BIOS password by attaching a dongle to the parallel port which crosses a
number of the pins. The pin out is:
Pins
1-5-10
2-11
3-17
4-12
6-16
7-13
8-14
9-15
Some Toshiba's can be convinced to bypass the startup BIOS password if
you hold down the <LEFT-SHIFT> key while booting the system.
remove the cmos cell andremove the battry and setnbay the laptop 1hrs and after ........add battry without sell and after resert the bios password pls insert the cmos cell ...............ok
Please install this one as this is the last official BIOS /and seems old ebough to be the one you had originally/: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1372980&rpn=PSAA8U&modelFilter=A105-S4054&selCategory=3&selFamily=1073768663&selModel=1372980|PSAA8U
This is BIOS v.6. If this is the BIOS tat you installed and gives the screen error please tell me and I'll try to find an older version.
hello i am bhaigi i know that the bios password is break if you are pikup the jumpher of cmos and their battry and run the computer.
restart the computer and put the jumpher his proper place
