E-Machines eMachines Desktop PC Logo
Posted on Jan 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emachines W3050 THE ETHERNET PORT IS NOT WORKING
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1703
Points
Buy a new PCI ethernet card and install it.
Anonymous
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on Jan 04, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
239
Questions
0
Helped
117319
Points
620
Can you find it in your device manager, If you see it in there and there is a yellow ? mark. open it and update it if you don't find it there you will have to go to you computers manufactures web and find you Ethernet driver and install it. reboot it on your on your way..
1 Related Answer
Anonymous
  • 115 Answers
  • Posted on Mar 04, 2010
SOURCE: Cannot find Ethernet, Video and Audio drivers for
the following links will help you, same as 3052
http://downloads.emachines.com/drivers/bios/D00221-001-002_readme_em_us.txt
http://emachine.com/support/drivers.html
http://global-download.acer.com/GDFiles/Driver/Others/Others_eMachines_4.46_XPx86_A.zip?acerid=633937006283283102&Step1=Desktop&Step2=W%20Series&Step3=W3052&OS=X01&LC=en&BC=eMachines&SC=PA_6E
Testimonial: "Thank you for all the help much appreciate it"
Looking for a ethernet port for a emachine t3265
I assume you have a bad internal ethernet port and are looking to add an internal board..
Manual is here:
eMachines T3265 Manual
assuming you have a free pci slot, these will work:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=pci%20ethernet%20card
USB WON'T WORK ON EMACHINES W3050
  • Verify in BIOS the devices are enabled
  • Verify in device manager there are no driver problems and the devices are not disabled
  • Open the case and verify the cables for the front ports are plugged in all the way
Emachine doesn't recognize the ethernet cord when plugged in
Sounds like the integrated ethernet port has gone bad. You can install a new ethernet card in one of the PCI expantion slots. Then plug the ethernet into the new card, this should take care of the problem. You can not repair a bad integrated ethernet port.
Emachine t3626 internet port can it be replaced
Absolutely!
The Ethernet port on your eMachines is part of the motherboard.
It is attached directly to the motherboard.
The eMachines T3626 Desktop PC, is supposed to use an
ECS MCP61-P (AM2) motherboard. (Cannot verify)
(Elitegroup Computer Systems. (AM2) refers to the processor socket )
http://www.ebay.com/itm/MotherBoard-eMachines-T3626-T5062-T5234-W3622-/320528791641
(Also scroll down for a larger photo of the motherboard )
The Ethernet port is in the group signified by the letter A, on the left.
The group signified by the letter A, is in the I/O area.
Input/Output area. This is where Input, and Output devices are attached, TO the motherboard. (Using the motherboard's chipset)
Now look down the motherboard, to the two long white slots.
These are PCI slots. Signified by the letter I ( i )
If one of these slots is not being used, plug in an Ethernet Card, that is PCI.
If both of these PCI slots are being used, use the small white slot above them, signified by the letter H.
This is a PCI-Express x1 slot. If it is available, use it.
Use an Ethernet Card designed to fit, in a PCI-Express x1 slot.
Example;
PCI Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=771339&CatId=1175
PCI-Express x1 Ethernet Adapter Card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
[ Note*
The PCI-Express x16 slot that you have, (Orange in color, above the white PCI-Express x1 slot), is for a graphics card.
It is ONLY for a graphics card.
The PCI-Express x1 slot is NOT used for a graphics card ]
For additional questions please post in a Comment.
(If you would like the proper procedure for installing a Ethernet Adapter Card, in your eMachines T3626, also state in a Comment)
Regards,
joecoolvette
3helpful
Where can i buy a replacement external ethernet port for a emachine?
You don't buy an ethernet port, you buy a new PCI LAN card hat you can find in every IT shop for $10.
E-Machine power supplies
search in this page
http://www.cputopia.com/emachine-480w-d-series-d3415.html
Trying to reload Windows XP on an emachine w3050 and wont find the harddrive. harddrive does show up in BIOS. so what am I doing wrong>
Go into bios and be sure the unit is set to boot to the DC/DVD when you boot up the unit.
clean the disk with windex - it helps to make it easier to read
Emachines W3050 desktop
Here ya go:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W-Series&model=W3050
Enjoy!
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
