Kenmore Elite 45986 Front Load Washer Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code F35 - Kenmore Elite 45986 Front Load Washer
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Nov 05, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
11300
Points
117
F35 code is the analog pressure switch needs to be replaced.
  • eufloria Sep 27, 2010
    where would I find the part #
1helpful
What does error F35 mean?
It helps to have FULL make and model in such questions, but here are a few ideas
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor.
Jun 4, 2011
F35 error code appears during cycle - iFixit
https://www.ifixit.com > Answers > View > F35+error+co...
About
Whirlpool duet washer f35 error code
https://all-errors.com > whirlpool-duet-washer-f35-error
The F35 error code in the Whirlpool washer indicates some problems with the water level pressure switch. This sensor is responsible for measuring the amount ...
Troubleshooting the F35 Sud Error Code in the Whirlpool Duet ...
https://www.youtube.com > watch
PREVIEW
12:49 Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam Washer · For more tech advice on ...
YouTube · SamuraiRepairman · Oct 5, 2013
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
5helpful
2answers
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
1helpful
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
1helpful
2answers
Error code washing is delayed wil wash half the clothes
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2helpful
5answers
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
5helpful
2answers
Error code f35
konica f 35 eror code
Alexander
vince
