Examine the markings on the battery. It is likely to be a 1.5-volt Silver Oxide or Alkaline battery. It doesn't matter which one you use, although the Silver Oxide battery can handle heavier energy-consuming loads, such as a multifunctional chronograph. It can be purchased from amazon, here: watch battery 1 5V silver oxide 357 SR44 SR44SW 10 pack. I hope this was helpful. Cheers
Simon
The battery you need will be what is in it now. If you don't have a battery in it now you would need to know the size of the battery cavity or the movement number to determine this.
But let me warn you. Changing the battery on a Rado watch is not for an amateur. Rado glues the crystals on their watches and the way they do this with the snap on case backs 99% of the time you will break the crystal. To replace the crystal will cost you about $400+ because they won't just replace the crystal. they will force you to have the watch serviced as well. They play this game where they refuse to replace the crystal if the watch isn't serviced.
So trying to save a few dollars on a battery replacement most likely will cost you several hundred.
Consider this before you try to replace the battery.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
SOURCE: Rado Watch
I brought mine online from http://www.ernestjones.co.uk/webstore/browse/N/65+4294967253
You are better off getting your watch from a credible supplier like Ernest Jones as they come with a guarantee..
SOURCE: rado watch
Not likely, Best to send it to us for evaluation. It's free! www.Finewatchmaking.com Donald McPherson C.W.
SOURCE: watch hands need fixing, re-oil,
I had the same problem , you need to go to a watch store and buy a watch pin to fix the band ,they should install the pin for you .
SOURCE: Rado watch stopped working
It sound like a fault. Be careful who looks at it though and what they charge - a complete new quartz movement for most watches, even fancy ones like your don't cost as much as £90 so almost all of what you are charged is labour.
