Ok take a putty knife and slide it between the top and front panal,,,, slide it twords the edges until you feel the clip...then push in the clip,, the top will pop open when you have both pushed in,,,,
lift the top up and prop in some manner look down the edges you will see two 5/16 inscrews, take those off and the panal will fall forward
loook under the tub and on the cabinet at that heiht,, if you see a black ring on the inside of your cabinet,,,,, unless your comfortable dooing a shaft seal id stop right there..
if no black marks
put a tub of water in the machnie let it fill
then put it in spin becare full but you should be able to see where the leak is comming from
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
heatman101
p
