InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
Posted on Jan 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loses the computer connection and just keeps searching
The computer is found, the image is displayed correctly and then about a 1/2 hour later is suddenly can't find the computer and just keeps searching. Turning the projector off and on, it finds the computer, shows the image for about a second and then searches and searches for the computer.
Restarting the computer and projector it will do the same thing.
martin hogg
Level 2:
Scholar:
  • Expert 157 Answers
  • Posted on Jan 05, 2008
martin hogg
Expert
Level 2:
Scholar:
Answers
157
Questions
0
Helped
76408
Points
263
Check connections to the computer, if USB connection, try another USB cable.
  • martin hogg Jan 06, 2008
    check connections to the computer, if USB connection, try another USB cable.
    It sounds as if the pc is losing its handshake with the projector, this happens quite a lot if projectors are getting moved about, leads can work slack etc and a re-boot is normally required.
A
Anonymous
Also try a factory reset in the menu options. If that doesn't work its caused by internal hardware failure. If the LP120 is out of warranty don't bother sending it in because you will be soaked over $500 for the repairs.
1998 Toyota Camry. Why does my car lose power while driving, then an hour later it starts back up? Replaced fuel pump minus that filter, air filter, fuel filter.
Didn't I answer this yesterday?
You need an auto electrician to connect a professional grade scan tool computer, and set it to record live data and take it for a test drive. It will record exactly what goes wrong when the car loses power. That will dictate the fix. This type of fault you can't just guess.
Ideas here
https://www.google.com/search?q=1998+Toyota+Camry.+lose+power+while+driving
How do I set the time on my delonghi coffee maker?
hi hazel.
this is all i could find.
How to Set Clock on Delonghi coffee maker? Plug the appliance in; when the coffee machine is connected to the outlet for the first time, "AM 0:00" appears on the display. To set the time, press the SET CLOCK button (fig. 1) and keep it pressed until the correct hour is displayed: then release the but- ton. The time can be set at any moment.
important safeguards save these instructions - De'Longhi
www.delonghi.com/Global/InstructionManuals/GB/GB-1321026IDL.pdf Search for: How to Set Clock on Delonghi coffee maker?.
How do set the time on my delonghi coffee maker Google Search
2helpful
Can Chromecast damage TV? I recently bought a Chromecast and it worked fine. Then the picture disappeared, but I still had sound. Today I reconnected it to test it, and one hour later I have no sound
It won't damage the TV. Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Type in the brand name of your device, in the search box at the display window, and press enter to get all related posts. It will make surf easy.
Is there display drivers available for my NEX Plasma TV model PXT-42SX1B. I have a Computer that has a HDMI output which I can connect to my TV, but have not been able to correctly setup the display...
I'm sorry for the difficulties you're experiencing in viewing the Desktop correctly when connecting a computer to the TV. Unfortunately, there are no such drivers available for TV to make it compatible with a computer.
Please understand that the image from a connected computer will not display in full screen because of the difference between the display resolution of the television and the available resolutions on the computer. Setting the WIDE MODE (Zoom) option on the television to Full 1 or Full 2 will stretch the image to fill more of the television screen but will not fill the entire screen. This is normal operation.
I have searched online and found that 1024 X 768 will provide better experiencing than other resolution. It is required to set the resolution in the computer before connecting it to the TV. Please install if graphic card updates available from the computer manufacturer so that it will give option to select resolution in some cases.
Thanks for understanding. Please let me know if you require any clarifications.
I have been trying to get on facebook now for the last 8 hours. it keeps coming up as connection problems...i know i am connected to the internet though..it gave me 3 options to try which are, 1, refresh...
Hello
First reboot your pc.Then go to control panel .internet options.Clear and delete all cookies and data.
Next,be sure your using the latest version of internet explorer 8.If not it can be found here.
http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
Next use a anti virus program to clean the pc.
3helpful
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Laptop keeps losing wireless connection
make sure the wep key you apply it is correct.just reconfgure the wireless connection.
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Keep losing connection
get rid of rthe Dell; router and never buy dell anything Dell is made by DILLS use a proven brand of router
1helpful
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
