SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Thanks.
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
SOURCE: my bosch 1200 classixx WAE24164GB will not spin or
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Your pump/filter is plugged. (E4) There
is a round door on the lower front of the washer. There is a small hole near
the door. Put a small screwdriver blade in the hole, push in just a little, and
you can rotate the door clockwise, the door will come out and you can get to
the problem. When the water is drained
in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter.
When you unscrew this, all the water left in the washer will spill out onto the
floor. Use a plastic bag to catch this or a small pan.(later models have a
drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find
the source of your clog. Remove it, clean out, screw the black connector back
in. You can check with rinse, if you
want to make sure there are no leaks. Put
the door back on and rotate.
Pl rate me 'very helpful' for the free help, thnks!
SOURCE: my bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
