(configuration genie) user admin connot log in
Try using the password 1234.
If this fails look for a small hole in the unit, normally marked reset. Unit must be powered, press and hold the reset button for about 3-5 seconds, then release. Note:a tool may be required to reach the recessed button.
Then try the default login and password again.
After looking at the manual it recommends holding the reset button down for 10 seconds, and waiting several minutes for it to fully reboot and stabilise.
My old routers also has admin telnet access, it's "old sshool" these days but it would not hurt to try it.
open a DOS window using the command cmd. The type telnet 192.168.1.1
See if you get a login prompt from it. It might allow you set another password and so get over this problem.
Best of Luck.
Spare head 2.
have tryed this with no solution to ongoing problem thank you for your speedy reply
thank you will give this a try thanks a lot
