Question about Jenn-Air 35 in. JEC9536ADS Electric Cooktop
JennAir Elec Cooktop Problem
My cooktop center burner (two elements) is behaving erratically. It seems to be all or nothing. What part do you think is causing this? Thanks.
  • Robert Kays Jun 26, 2013
    I have a simular ptoblem and I am thinking its the switch
I'VE HAD THE SAME PROBLEM WITH MY JENN AIRE. THE FIX IS REPLACING THE CONTROL KNOB. IT COSTS ABOUT $38. MARK ALL WIRE CONNECTIONS BEFORE REMOVING FROM OLD SWITCH. NEW SWITCH WILL BE SIMILAR BUT NOT IDENTICAL. YOU MUST ALSO USE THE JUMPER WIRE SUPPLIED WITH THE NEW SWITCH TO GET THE INDICATOR LITE TO WORK.
Posted on Mar 28, 2008
    Master:
  • 619 Answers
The selector knob having lose contact the elements are for full adjument , the wire connection are rust and corroded need to clean terminal of elements.
Posted on Jan 05, 2008
6ya staff
SOURCE:
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
What do error codes E51, E52, and E53 indicate?
This link lists the error codes for your cooktop: Needapplianceparts com
Specifically, it's a "sensor break" in your front and center burners.
The solutions they recommend:
* Verify element temperature sensor is correctly connected to the generator circuit board
* Replace element if temperature sensor resistor value is not approximately 1000 ohms (blue wires) at room temperature
* Replace associated generator circuit board
Jan 12, 2014 | Electrolux 30" Electric Hybrid...
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Oct 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air 35 in. JEC9536ADS Electric Cooktop Logo
390 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
