Dell E153FP 15" LCD Monitor Logo
Anonymous Posted on Jan 04, 2008
Dead dell flat screen lcd model E151FPb
I have recently been given one of these and all it does when you apply power to it is emmit a real low chirping noise. been looking around for information and all i found was to check cold solder joints. the board looks fine. nothing looks burned. also found out by replacing Q604 which is 2N7000 and says can be replaced with 2N2222 with 10k resistor which i didnt quite get where to place it if its true. any info would be appreciated..
please email me at [email protected] with whatever info.
thank you
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jan 04, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
4008
Points
24
First find out why you need to change this transistor, if it is shorted or open then replace it , but be carefull when you substitute parts which could create havoc, to check the spec's of these to components look up the 2n7000 note the specs and see how close the 2n2222 relates to , my recommendation is to get the original.
1helpful
How do I upload a solution? I want to tell people how to disassemble the Dell E151FPB LCD monitor.
You will need to sighn up for FixYa, seeing that you've listed this question I'm guessing you've already done that. Then you can create tips, once you have created a tip that is of good quality and length you can apply to become a Premium tip expert.
2answers
Dell Monitor Failing
its the problem in the EST of the monitor.just get it replced to solve the problem.
pls do rate the solution
thanks.
regards.
fixya expert team
1helpful
My DELL E151FPb LCD Monitor turns to white screen.
unplug the monitor on at the back fo the computer but leave the power plugged in and if you can see red,green ,blue bars jumpign around the screen it means that the monitor is good check the video card, but if you cant see the colored bars you need to get it repalce.this is monitor selft test process
Dog chewed cord in half. Not power cord - feed cord. I have it apart, where can I get a new cord. Its a Dell flat screen monitor- Model :E151FPb
You need a DB15 Video cable, they are available at say... Radio Shack, or the like, any good PC store should have them.
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
1helpful
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
1helpful
2answers
DELL LCD monitor E151FPb turn white
If the screen is all white light then you can have a number of problems.
One could be a bad video board, the next could be a simple loose wire from the video board to the back of the lcd screen OR a simple blown fuse on the back of the actual lcd screen can cause the same thing.
Snaps are all sround these things and can be really stubborn at times. Best to start the bottom first then work up each side to the top.
Something flat, thin and with a decent sharp edge on it will help. A pocket knife held parallel to the joint between the front and rear plastic works, you can also sharpen the edge of an old credit card with a file (nail file works) This isn't as strong as a blade , but safer if you slip !!
Fran
Wacko Dell E151FPB
that sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
