When charged V2 does'nt hold charge for long. It has worked ok in the past but recently it was charge d over night and lasted about twenty minutes.
Hi.
Most likely this kind of problems occurs when the battery is exhausted after a long time of using it.
because even intergrated (rechargeable) Batteries Wont Last forever. the chemical substances(lithium-ion) in it Drains after a period of charging/discharging(using the device).
Solution:
if you have a common Mp3 player, You can purchase a new fresh battery and replace it. its quick and easy.
i can instruct you if you want so.
First check ebay for the exact same battery that you have inside you Mp3 Player.
Learn More about Lithuim-Ion Batteries on HowStuffWorks.com
Good Luck
Thank You.
