Question about Tomtom GO 720 GPS Receiver
It shows a 'X' mark - Tomtom GO 720 GPS Receiver
My Tomtom go 720 shows an x mary and will not work
Posted on Nov 11, 2009
  • 3,741 Answers
The other users who faced the same error tried this instructions and solved the problem as follows:-- We have a result!
After calling the helpline to find it was number unobtainable! I returned the unit to Halfords who called another helpline number. They took my e-mail address and when I returned home an e-mail was waiting with the following instructions which worked.
I now have a fully functioning TomTom! Thanks for the advice fellas:
Thank you for contacting TomTom Customer Support.
In this email you will find the solution for the error on your TomTom. This solution can be used in the following situations:
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
Posted on Nov 03, 2009
6ya staff
SOURCE:
Timing marks 1997 Taurus SHO V8
Register for free at autozone.com. You can show make, model, year, and engine size-for as many vehicles as you want to list. Vehicle specific repairs and information like timing marks set up are found under the repair guides.
Apr 02, 2014 | Ford Taurus Cars & Trucks
Gears marks
What gears are you talking about if it is the timing belt put the no 6 or no 4 piston on top dead center rockers are rocking and the mark on the harmonick balancer shows marks on top dead center and the over head cam has a mark on it to lines up with a mark on the timing cover mark.
Aug 19, 2013 | Mitsubishi Pickup Cars & Trucks
Witch mark do i use the f or the t mark to put a 81 honda xl125 dirtbike n time
The T mark shows TDC usually used to set timing for camshaft etc...
The F mark shows the firing point and is used to set ignition timing...
Here is a link to download a free service manual...
http://www.manualedereparatie.info/manuale/honda/Honda_XL_XR_TLR_125_200_200_R_1979_1987_Manual_de_reparatie_www.manualedereparatie.info.zip
Nov 19, 2012 | Motorcycles
The question mark is over the number 6 and shows as A triangle. The backwards slash shows as an A with A mark over it. What is going on.
go to the two letters in the taskbar[EN] remove all keyboards and add new ones and it will be fixed
May 10, 2010 | Acer NSK8458AN Keyboard
I taped 8 hours of programming in LP mode and want to burn it onto disc. Can I use the divide title mode to split the title into 3 segments so I can fit on 3 discs?
Yes, go into hdd list of recorded shows and select show
edit, chapter mark, find about 1/3 of show, select mark,
yes, back 1 menu under chapter mark is split or cut,
just select and you now have 2 files, 1/3 of show and 1 2/3 of show, just repeat, for 3 parts. and burn to dvd.
Jan 07, 2010 | Philips DVDR3576H DVD Recorder
Timing belt marks
The crank pulley should have a mark that is approx 12 o clock with an arrow on the block. Both cams should have marks,'I' for the rear cam and E for the front, and the dowel pins (in the end of each cam)AND the marks on the cam pullies will be 12 o clock with the back cover. Be SURE you TORQUE the crankshaft bolt to 120 ft lbs.
Dec 16, 2009 | 1992 Mazda Protege
Timing marks on 2002 2.4 litre engine
They'll usually be offset just a hair, and I mean a hair. If it's a tooth off, it's wrong. Make sure the mark on the oil pump is lined up with the MARK on the gear, not the tooth. I think the mark is actually lined up with the trailing edge of the tooth.
Apr 15, 2009 | 2002 Chrysler PT Cruiser
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
Blue mark
If it is on the lens itself , you can simply wipe it off.
If this mark shows even when there is no signal in the unit and you wiped of the lens , you might be looking at a burnt LCD
Jan 14, 2008 | Hitachi Performa CP-RS55 Multimedia...
Why does a question mark show up when i recieve a picture message
Go to your Icon Glossary under tools to get a discription of the the question mark.
Jan 03, 2008 | Samsung SCH-u340 Cellular Phone
Tomtom GO 720 GPS Receiver Logo
397 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
