Epson 2580 Perfection Photo Scanner  Logo
Posted on Jan 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red light comes when powered
Some seconds after I put the power plug into the outlet the flashing green light turned to a flashing red color.
Of course, after I selected Document in the Smart Panel, I received an error message. It indicated that the scanner connection was having a problem. I connected and reconnected all the wires.
In addition, I uninstalled and reinstalled the software, including the driver.
As well, I tried connecting the scanner to another of my computers, and, yet, I continued to see the flashing red light and the same problems indicated above.
Is there anything else I can do. Thank you in advance.
Anonymous
Level 2:
Novelist:
  • Expert 110 Answers
  • Posted on Aug 22, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
110
Questions
0
Helped
73743
Points
222
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (located on the bottom of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
I hav icraig slimbook model CLP288 red light that indicates its chargeing comes on but I push power button green light very brief comes on then off screen never comes on .plz help
Try plugging the charger into a wall outlet if you are currently plugging it in a power strip. If you are not try plugging it in another wall outlet. If that doesn't work you can try a hard reboot if the battery is accessible. To do this turn off the slimbook, unplug it, take out the battery and hold the power button down for 30 seconds. Once done put the battery back in, plug it back in and turn the slimbook back on.
For other IT soultions try visiting: https://www.youtube.com/user/jrlake2414?sub_confirmation=1
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
2answers
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Sharp lc-c4067un troubleshooting flashing power light flashing red & opc light flashing green tv will not come on and can not shut off @ tv or remote.
Unplug your devices from the power outlet for atleast 10-20 seconds. Then plug back in. This could possibly be the easiest fix for you.
I hope this works for you,
regards,
Nico
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
1helpful
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
1helpful
2answers
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
