Samsung 50'' plasma model ps50b450b1wxxu keeps losing all stored channels and needing re-tuned,tv says weak or no signal, it is only 3 weeks old, is it something i,m doing wrong or is the tv faulty?
    President:
  • 1,284 Answers
If you are always needing to auto program the tuner then I suspect a faulty main board. Bring it back as it should be under a 30 day return policy..
Posted on Nov 03, 2009
Anonymous
SOURCE:
Correct inverter board for Samsung plasma TV
http://www.lcd-plasma-parts.co.uk/bn41-01180a-bn94-02845a-samsung-ps50b450b1wxxu-main-board
read the page above to get pointed in the right direction as it helps to explain what is required to order the correct board
Jan 02, 2017 | Samsung Televison & Video
Will not tune in channels on auto store
Well, there's your answer then. You have poor aerial signal so the TV cannot lock on when tuning. You need to sort out the reason why there's "Poor or No Signal" You need to fix the aerial, not the TV. I would have thought that was self-evident, surely?
What kind of aerial are you using. Do you know it works? Check out the aerial cables for breaks or badly fitted connector plugs.
Sep 15, 2014 | Samsung PS42B430 42 in. Plasma TV
Keep losing signal
You have a weak signal. There are many possible reasons for this, such as:
The aerial has moved or there is a poor connection.
You are tuned to the wrong transmitter.
Aug 05, 2014 | Humax Televison & Video
Can I tune in my samsung 2-3 year old TV to an old non-digital VCR?
This would be easier to answer if you had included model numbers of both. Check the connectors on each and you should find color-coded connectors marked with matching inputs & outputs. You will need to connect the outputs of the VCR to the matching inputs of the TV. The signal coming from the VCR will, of course, be analog so you may need to set the TV on channel 3 or 4 and select the appropriate inputs of the TV via the main menu. It should state 'Analog.' If you are concerned about keeping stereo signals on the proper sides, red=right, white=left.
Apr 13, 2011 | Samsung TV Remote Control
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Samsung plasma TV tuner dropped a channel.
you can try a rescan of your channels if that does not work then you will need to rplace the mainboard iam assuming your NOT using a cable box
Dec 07, 2009 | Washing Machines
I have a samsung 50" plasma tv with biult in freeview how do i tune it for the change in new freeview channels
Have a digital antena or a roof antena set up use the
end of the coalix cable hook to ur input antena hole u done,go to the menu make sure u in air setting not
cable,press scan u should get what in the Free air signals.
Sep 30, 2009 | Samsung 50 in. Plasma TV
Samsung lcd tv is saying low or weak signal when trying to tune it in
you can only use your tv to scan for channels with an antenna or if you have that tv hooked to cable television. use your Directv receiver to scan for channels, if you have an antenna hooked up to it. --------------- click this link for more help http://www.highdefforum.com/directv-forum/77638-new-lcd-tv-d-sd-no-weak-signal.html thaNKS.
Jul 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Feb 23, 2009 | Samsung Televison & Video
50 " Samsung Plasma TV
Get the tech supplier to tell to the manufacture and the store what he told you.
Physical damage on any electronic device is very hard to have serviced under warranty. I have never seen a plasma display crack on its own. But, anything can happen.
I once saw a man drop a newly bought plasma TV in a parking lot outside from where he bought it and the screen broke. He never even made it home from the store!
Maybe you should contact a lawyer or someone who can give you legal advice about how to proceed with this. In different countries and different states the consumer protection laws are different.
Jerry G.
Sep 26, 2008 | Samsung HPT5054 50 in. HD-Ready Plasma...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
