Question about Whirlpool 21.6 cu. ft. Top Freezer Refrigerator GT22DKXG
This is usually caused by a cloggg in yout defrist drain weather covered in ice or clogged at the bottom.
when you sytem goes inot defrost the water has no where to go
if you can take off the back wall of the freezer and clear the drain
you will also want to take off the back and make sure the drain to the pan is clear as well
you can check it clear by poiuring water down it and make sure it ends up in the pan
a very easy reapir
Posted on Nov 04, 2009
http://www.appliancepartspros.com/partse...
i mean the back wall in the freezer,
you shouild be able to remove the back wall behind the fan is the evaporator coil
Hi.
Check if it is condensation, or if you have a leak from water lines to dispenser, or from the back of the ice maker.
There is a drain hole getting from freezer to fridge, ensure that this is not obstructed.
Regards.
Posted on Nov 03, 2009
sorry for the delay.
Position of drain hole may vary depending on the model, if you give me the full number as printed on service tag I will be more specific.
thanks
Hi , I need model number from service tag to give you further instructions.
Alternatively enter model number here and see if you can get the diagrams for your model.
SOURCE: water leaks from vents in fridge
This could be your heater has malfuncutioned and what is happening is that when you turn it on the freezer is trying to get cold and frost and the heater is staying on and letting things melt very fast and causing a water problem
Posted on May 21, 2009
SOURCE: I have water collecting on the iside of the
I am going to assume you have a defrost condensate blockage in the rear of the freezer and behind the rear panel where the evaporator dreains condensate after each defros. Please correct me if I am wrong.
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 27, 2009
Testimonial: "Your diagnosis was spot on. I had ice in the drain tube. Everything is ok now,thanks to you. Thank you so much."
SOURCE: water leaking from freezer into refrigerator
This is most likely due to the defrost drain being restricted, here is a link to help explain how to correct the problem. Let me know if this helps. Thanks.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Posted on May 03, 2010
Aug 15, 2014 | Frigidaire Refrigerators
Apr 24, 2012 | Refrigerators
Jul 02, 2011 | Whirlpool GR9FHMXP Top Freezer...
Jan 27, 2011 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Sep 27, 2010 | Kenmore Top Freezer Refrigerator
Feb 09, 2010 | Refrigerators
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
May 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Feb 27, 2009 | Kenmore Refrigerators
Jan 11, 2009 | Amana ATB1832AR Top Freezer Refrigerator
190 people viewed this question
I have repalced the ice maker and the hose is attached. Where is the drain hole from the freezer to fridge located?
Where is the drain hole?
GT22DKXGW01
EJ2716434
TYPE C22TFA99
That solution makes alot of since. The only question I have is when you say back wall of the freezer does that mean the panel inside of the refrigerator or the back outside wall?
Thanks for your help. I removed the back of the freezer, cleaned out all of the ice and found the plugged drain hole. It was full of ice. I cleared it out, took off the lower back of fridge and poured water into the darin hose to make sure it was draining through hose into the pan. Fridge is working great now!!!!!!!!!!!!!!
