Kodak EasyShare Z612 Digital Camera Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak EasyShare Z612 will not format SDHC 4.0 GB card.
Anonymous
Level 2:
  • Expert 262 Answers
  • Posted on Nov 03, 2009
Anonymous
Expert
Level 2:
Answers
262
Questions
0
Helped
98273
Points
747
Z612 is not compatible with SDHC card., the compatible and recommended Memory card you can only used is 1GB SD card or 2GB SD card. Gudluck!
5 Related Answers
  • 102366 Answers
  • Posted on Jun 14, 2010
SOURCE: how do i format a kodak memory card 4 gb sdhc for
Unfortunately. you don't. The Z612 works with SD cards, not SDHC cards. You're limited to cards 2GB and smaller.
  • 102366 Answers
  • Posted on Apr 28, 2010
SOURCE: i have a sandisk sdhc card but it wont format on
The Z612 uses SD or MMC cards. It will not accept SDHC cards. You'll need to use cards 2GB and smaller.
Anonymous
  • Posted on Aug 06, 2011
SOURCE: when i install team micro
I had the same problem.However, I found out that Kodak easyshare z612 is type 2 in memory cards. The Type is a small number located to the right of the number of Gb or on the top. It has a circle around it. The 4gb SD or anything higher usually has type 4, that's probably why it kept saying format, because you need a smaller type of SD. I got my type 2 memory card and returned the 4gb and now it works. Hope this helps.
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Nov 12, 2009
SOURCE: I purchased a PNY 4GB SDHC memory card to use with
You simply insert the memory into the camera, switch it on, go to the menu and then scroll through to Format and then accept. This will then take a few minutes and format the memory for use in the camera. Make sure that the batteries are fully charged before doing this.
  • 102366 Answers
  • Posted on Mar 04, 2011
SOURCE: how do you format SDHC 4 GB card for c703 kodak
You don't. The C703 works with MMC and SD cards, not SDHC cards.
Sdhc card will not format
What type and size memory card? The Z612 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
HOW do I format SD cards for Easyshare Z612? Can I use a "PNY 4GB SDHC card?"
You can Format by entering the camera's menu and find the format section. Click Here and see Pages 36-39 for detailed instructions on formatting your SD Card. Also your camera is not capable of reading the High Capacity SD cards (SDHC) so you will have to stick to the SD cards (2gb or smaller)
2helpful
2answers
When i install team micro sdhc 4gb memory card in kodak easyshare z612 it says format .i select format but it keeps asking to format or cancell
First check make sure the SDHC card is unlocked I'll provide a diagram for that also I just checked your camera's memory capacity and it's only good for a 1 gig SD card which if using an SDHC memory card might go to 1.5 stretch to 2gig maybe but not a 4gig. My first impression is you got to much memory card for the camera. You might be able to go to the Kodak site and download updated firmware to allow the camera to function with the larger card but that's a maybe as well.
Here are the diagrams
And the memory capacity chart for your camera
I bougth a 4GB SDHC for my kodak easyhare Z612 my problem is i coudnt format
The Z612 works with MMC and SD cards. It does not work with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible.
1helpful
My kodak Easy Share Zoom Digital Camera Z612 will not format all the SD cards I buy..the last one I tried was SDHC 4GB. Why not? the SD card that came with the camera is 1.0 GB Digital Media Secure...
The Z612 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to stay with SD cards, 2GB and smaller.
7helpful
How do i format a kodak memory card 4 gb sdhc for my kodak easy share z612
I bought a new 8GB memory card for my kodak easyshare Z612. However it's not formatting. Help!!
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
EasyShare Z612 Digital Camera: I bought a new 8GB memory card for my kodak easysh...
5helpful
2answers
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
4helpful
I have a sandisk sdhc card but it wont format on my kodak easyshare z612 camera
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
