Phil,
good call, you can verify this by visualy checking your break package,
take off the toe kick and look in the milk stool
the brake for this model is three pads that slide into the brake wheel
and engage to lock the hub on aggitate,,,,
i am including a parts list and pictoral break down
check your pads,,,, its an easy rerair
you will need a 3/8 ratched open end
each pad has two bolts
you can remove and repalce all with out removing the tub
it just takes some time and paitence
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=22189&diagram_id=653315#d653315
9-10 times you will not need to repalce the rotor
hope this helps
Thanks will try that. Phil
