Reconnect all the wirings of the speaker set. Left and Right sound connectors from the subwoofer properly.
Testimonial: "Everything is plugged in properly. I've replugged and still nothing, still out. Headphones right piece is out in the remote but not in the comp"
Okay..,what I want you to do right now is need a little work. You have two satellite speakers right?Right and Left., and in your sub woofer there is three jack holes, which is red for right speaker,white for left speakers and power supply. What I want you do is to inter change the connections of the satellite speakers. The one you said that will not produce sound will be plug into the left jack hole,which is the right speaker and also the left speaker will be plug to the right jack hole. If still no sound of the right speaker that being plug into the left jack hole then your it is broken. Look also the volume balance in the volume properties in your computer.
Iphone 3g right side not working solution
ok i've done what you said...i placed I've taken the speakers and switched them at the plug source (which is located at the subwoofer) and now the right speaker works but the left is out. So leads me to conclude that the right input (red) is messed up somehow...got any advise?
