Can Nokia 6350 get unlocked with codes?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If it does not work Visit http://www.unlock-free.com/nokia/
or
http://www.unlock-free.com/nokia-master/
And follow the site instructions.
You may try some default codes.......
To unlock your Nokia 6350 mobile get the instructions here in this site http://www.mobileunlockguide.com/ about unlocking the mobile ,
Then get the Unlock code in this site http://www.mobileunlocksolutions.com/unlock-your-phone/rs1wp2/ according to the network you reside ..
This site provides good result for unlocking mobile with unlock code ..
I used this site for unlocking the mobile & got good solution , make use of this site for unlocking the mobile & gain solution as i got .
SOURCE: unlock code for nokia 6350
you can unlock it here
http://www.onlinegsmunlock.com/nokia-6350/rs7wp9/
check, if your model is available in the list
SOURCE: i want to unlock the puk code on my nokia 6350
Service Provider will Provide the PUK Code for You..Get it that from them....
SOURCE: i need an unlock code for a nokia 6350
you can get unlock codes here
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
