SOURCE: acer extensa 4210
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
SOURCE: Aspire One NO turn on at all
while the laptop is still under warranty do not try to open it! I would recommend that you take the laptop back straight away and have them replace or repair it. Its your right as a consumer.
kind regards
SOURCE: acer not work
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to
flash the BIOS even if the system doesn't boot anymore. It's only meant
for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected.
Press Fn+Esc, keep it pressed and press the power button to turn the
AA1 on. Release Fn+Esc after a few seconds, the power button will be
blinking. Press the power button once. The AA1 will now initiate the
BIOS flash, do not interrupt it under any circumstances. After a while
the power button will stop blinking, and the AA1 will reboot shortly
after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it
doesn't reboot by itself wait 5 minutes before turning it off, just to
be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
SOURCE: No S-VHS output signal?
once the cable is plugged in, press the fn (function) button and f5 I believe to switch display to the tv (it may be f6 or something else)
SOURCE: Acer Extensa 5630EZ does not start
Not really sure--could be a motherboard problem. But you say the computer is less than 3 months old. That means it's still under warranty--so call their tech support. You paid for support when you bought the machine, so I would use it.
