Sentry Fireproof Safe Logo
Posted on Nov 03, 2009
Cannot open sentry safe, model 1230, have combo
Cannot open sentry safe, model 1230, have combination
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3055
Points
Cannot open sentry safe, model 1230, do not have combination
Model 1310. How do I recover from lost combination?
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupFor over 80 years, SentrySafe has built fire-resistant safes that provide security ...Combo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership ... the notary process if you do not have your username, password, or combination. ... An override key is needed to unlock the safe.Missing: question
' Sentry® Safe ' SFW
tip
I have lost my sentry safe key or combo
<span>Hi.<br /> <br />Sentry respects strong security standards. There is no simple way of hacking a safe if you loose the combo. If there was a simple way of opening a Sentry safe, Sentry would withdraw the model from the market.<br /> <br />When you own a Sentry safe you are supposed to register the combination in Sentry website. The combination will be held as encrypted data in Sentry server. After registration you get an user name and password that will allow recovering the combination.<br /> <br /></span><span>If you have already <a href="https://www.sentrysafe.com/CustomerCare/Store_Combination">registered</a> and need your combination now, <a href="https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination">you can recover your combination clicking here</a>.</span><br /><span><br />Most owners are not aware and do not register the combination.<br /> <br />If you have not registered the combination, then for security reasons you will be asked to send Sentry request your combination from the Customer Care team. The request must be accompained by a notarized letter stating you are the owner of the safe (form must be downloaded from website). The document can be obtained from any local Notary Public office.<br />You will also be required to pay Sentry $20, that is what Sentry will pay to verify with double check your identity.<br /> <br /></span><span><a href="https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination#">Page is the same published before, at the bottom the button to open Notary public form template.</a></span><br /><span><br />I know that the procedure is annoying, but that is the only way to get a lost combo. Sentry care to protect owners property and safety and security concerns impose use of this procedure.<br /> <br />Other useful links:<br /> <br /></span><span><a href="https://www.sentrysafe.com/ContactUs/Call_Or_Email_Us">Call or Email Sentry</a></span><br /><span><br />International websites:<br /> <br /></span><span><ul><li><a href="http://www.sentrysafe.co.uk/">United Kingdom</a></li><li><a href="http://www.sentryjp.com/">Japan</a></li></ul></span><span><br />Here US customer care number: 800-828-1438.<br /><br />Ginko.<br /></span>
on Nov 11, 2010 • Sentry Fireproof Safe
Sentry 1230. Have combination. What is the sequence to open it
the combination to open your safe is a very personal information that only should be known by the user of the safe.
Mo way that anyone may provide you this combination.
If you don't have it, guess your only possibility to get it is from safe's manufacture.
Call SentrySafe on 800-828-1438 or fin some other way to contact them trough their webpage
www sentrysafe com
I have a sentry fw123cs safe. It's open but i can't find the owners manual to ock and unlock i
Go to the Sentry safe website, http://www.sentrysafe.com/CustomerCare/Find_Your_Safe and click on "lost your combination" and they should be able to help you retrieve yours.
Sentry safe model number G1459C
There is no default combination. Open it with the key and reset it to your own combination.
https://www.google.com/search?q=Sentry+safe+model+number+G1459C+default+combination
I have misplaced the paperwork with the combo i have sentry 6250 how can i open it?
If you need your combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
4helpful
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking Sentry Fireproof Safe open.
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
2helpful
Can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
