Dehumidifiers Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every thing works but no water gathers in the bucket
No water in bucket
Anonymous
Level 3:
  • DeLonghi Master 43,501 Answers
  • Posted on May 14, 2010
Anonymous
DeLonghi Master
Level 3:
Answers
43501
Questions
0
Helped
10835189
Points
101584
There are many reasons for a dehumidifierEvery thing works but no water gathers in the buck - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their deEvery thing works but no water gathers in the buck - 2_bing.gif2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Why does the power light on my dehumidifier flash quickly?
without the model number I cant be 100% sure , but due to your description of the last thing u did , Id say the light is flashing indicating that the water catch bucket is not installed correctly back as it was before , most units have a safety that wont allow a unit to operate unless the water catch bucket is installed and M/T as this would allow it to dump water to the floor if it were not
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
My lg dehumidifier lhd45et8 does not gather water,it appears that an external hose was connected at one time and i don't know ifa piece was taken out to connect the exteranl hose and how do I get it...
If you are not getting water at all then the hose is not the issue...
If you are getting water and it is just not going into the bucket, then plug the hole were the hose hooked up with silicone caulk and a plug fashioned out of whatever you can find that size...
If there is no water, then the compressor has a freon leak or is bad and the dehumidifier is junk... it will not be worth fixing it as cheap as new ones are...
heatman101
1helpful
Overflow on floor
The problem you're having can be caused by a couple things.
1. The float valve in the top of the water collection bucket is broken or is stuck in the Down position.
Remove the bucket, and inspect the float valve for damage or sticking. If it's stuck in the DOWN
position, jiggle the arm of the float valve, to make it works freely.
2. The water collection bucket is not installed properly and water is leaking out the back of the
top of the bucket. When installing the bucket, be sure it's installed "squarely" into the bucket
holder from top to bottom and making firm contact with the bucket safety removal switch on the
rear wall of the bucket holder.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
1helpful
Our Haier dehumidifier, Model HD306 seems to be working okay except it is not gathering any water. Last year we had to empty the bucket every two days. The humidifier is in the same spot and under the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
My basement had a lot of water. My dehumidifier is running but is not gathering any water. What can I do?
It may be gathering water, but the tubing to the drain bucket may be clogged. Turn the unit off, unplug it and remove the drain bucket. With a flashlight, look up into the interior of the cabinet and you will see a small tube or water outlet. Using a flexible Zip Tie (at least 6' long), carefully insert it into the drain tubing or hole. And carefully move it back and forth. This should remove any clogs.
Also, check the filter on the unit, as it to may need cleaning, too.
If you've had this unit for a number of years and the above trouble shooting doesn't solve the problem, it may be time to replace the unit.
Also, if you continually have "a lot of water" in your basement, you might want to install a sump pump. In the long run, it's a better solution and will pay for itself in a couple of years.
8helpful
Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
1helpful
Dehumidifier not sure is working
There is water in the bucket or no water in the bucket? If there is water in the bucket then empty it and put it back. If there is no water in the bucket then make sure the bucket is all the way in, (there is a switch that senses the bucket). If the bucket is not all the way in the de-humidifier will not work. If you do not hear it, it is not working.
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
