Question about GE JKP20 Electric Single Oven
How do I replace my GE electric Bake coil? - GE JKP20 Electric Single Oven
    President:
  • GE Master
  • 1,922 Answers
Unplug unit,remove 2 screws at rear of oven where element comes thru wall, unscrew terminals,then reverse the procedure and then turn power on
Posted on Nov 04, 2009
2 Suggested Answers
6ya staff
SOURCE:
Doug Connell
  • 715 Answers
SOURCE: Bake coil does not heat enough
sounds like a bad element
Posted on Feb 09, 2010
My ge specta bottom heating coil is not working. What do a check first?
I just took apart mine and found the same problem. Broil and range work fine but nothing when the bake function is used. I pulled the heating coil and it showed open (infinite resistance). This could well be your problem too. Pull out the drawer on the bottom and you'll see where the coil connects. Pull it and check resistance with an ohm meter. If it shows open, that's probably your problem. It was pretty easy to pull and shouldn't be too tough to reconnect either.
Dec 21, 2009 | GE JKP20 Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
The igniter was bad i replaced it with a new one (seemed simple enough) but when i put it on broil or bake the igniter doesn't turn red, is there something i'm not doing?
The igniter is in 'series' with the gas coil that operates the gas valve. The gas coil is probably bad. You can replace the coil not the whole valve. Go to repair clinic.com and put in the model number and they will have it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 06, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Jul 15, 2009 | GE JKP50SH Electric Double Oven
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE JKP20 Electric Single Oven Logo
251 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
