You need to reset printer thorught software
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
[email protected]
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
