Apple iTunes Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Itunes won't install because no quicktime
Itunes won't install because I don't have quicktime...quicktime won't install correctly and I don't know why.
Anonymous
Level 2:
  • Expert 134 Answers
  • Posted on Nov 03, 2009
Anonymous
Expert
Level 2:
Answers
134
Questions
0
Helped
65284
Points
329
Use the installer which includes both itunes and quicktime player.
I can't download iTunes. I'm using windows vista.
Right click the iTunes install program and click "Run as an Administrator". This will give you full access. Letme know if this works!
EDIT:
What version of Vista are you running??? (eg Home Premium x86 or 64bit, etc.) and also, is your account a Limited or Administrator???
EDIT 2:
Also, have you installed Quicktime or iTunes ever before on your computer with Vista??? If you did, you have to login to the account that installed it before.
EDIT 3:
Vista is really weird with quicktime and iTunes., so basically your problem is that you have to be on the user name that installed quicktime, using the "Run as Administrator" option. Ive seen this before with Vista and it has to do with ownership permissions.
Problem is with iTunes
hi try this: The intention is to remove all iTunes and Quicktime software references. The following steps remove the software traces and worked on my machine. 1. Using add/remove programs uninstall Quicktime (click on Start ?> Settings ?> Control Panel ?> Add/Remove Programs) 2. Using add/remove programs uninstall iTunes 3. Right click on My Computer, use Search and remove all programs named Quicktime 4. Right click on My Computer, use Search and remove all programs named iTunes (except your iTunes download, so you won?t have to sit through another long download session). 5. Left click on Start, click Run, type ?regedit?, go to HKEY_LOCAL_MACHINE, click on SOFTWARE, and remove the Apple Programs folder (you may want to check in case you have other Apple applications, but all I had were iTunes and Quicktime in my Apple folder). Steps 1 through 5 should remove all traces of the software and now you can install iTunes. make sure you install all the latest updates from apple hope this will work for you :)
When I try installing Itunes half way through installing a pop up comes up saying- "Could not access network location %APPDATA%\." Can u help me fix this.
Please take note that the following steps is in assumption that you are using a Windows operating system.) As I have found out in the iTunes support in apple.com, this symptom may be caused by anti-spyware software preventing iTunes from installing correctly. One such application is SpyCatcher. Before installing iTunes, temporarily remove this software to allow the iTunes installer to complete.
If you are still having trouble installing iTunes for Windows, follow the troubleshooting suggestions described in this article.
General installation troubleshooting Important: iTunes installation is successful a majority of the time after completing these troubleshooting procedures. If one step does not resolve your issue proceed to the next.
1. Empty your Temp directory and restart
Windows XP:
  1. Choose Start > My Computer (or double-click My Computer on the Desktop).
  2. In My Computer or Computer, open the "C:" drive.
  3. Open Documents and Settings.
  4. Double-click the folder titled with your username.
  5. If you see a Local Settings folder, skip to step 10. If you don't see a Local Settings folder, proceed to the next step.
  6. Choose Tools > Folder Options.
  7. Click the View tab.
  8. Select the option to "Show hidden files and folders."
  9. Click OK.
  10. Double-click Local Settings.
  11. Right-click on the Temp folder and choose Delete.
  12. In the confirmation dialog that appears click Yes.
  13. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 11.
  14. Restart your computer.
Windows Vista and Windows 7:
  1. Choose Start > Computer
  2. In Computer, open the "C:" drive.
  3. Open the Users folder.
  5. If you see an AppData folder, skip to step 10. If you don't see an AppData folder, proceed to the next step.
  6. Choose Organize > Folder and Search Options.
  8. Select the option to "Show hidden files and folders." (In Windows 7 this option will be called "Show hidden files, folders, and drives").
  9. Click OK.
  10. Double-click the AppData folder to open it. If Windows needs your permission to continue click Continue.
  11. Double-click the Local folder to open it.
  12. Right-click on the Temp folder and choose Delete.
  13. In the confirmation dialog that appears click Yes.
  14. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 12.
  15. Restart your computer.
2. Completely remove iTunes and QuickTime
For Windows XP, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows XP.
For Windows Vista or Windows 7, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows Vista.
Note: Songs you purchased from the iTunes Store or imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
3. Install the latest version of iTunes
Once you have completed the above steps to Empty your Temp directory, Completely remove iTunes and QuickTime, and Clean up iTunes installer files on the computer, you can install the latest version of iTunes from http://www.apple.com/itunes/download.
Additional troubleshooting Make sure you have administrator-account access To install iTunes or QuickTime software, you need to be logged in as an administrator on the computer. If you're not sure if you have administrator-account access, contact the owner of the computer or your system administrator.
Get the latest Windows updates The first thing to do when troubleshooting an installation issue on a Windows computer is make sure you have the latest Microsoft Windows updates installed—to get the latest updates, go to the Microsoft Windows Update page.
iTunes and QuickTime software for Windows require Microsoft Windows XP or Microsoft Windows Vista with latest Service Pack installed.
Disable other conflicting software In Windows, some background processes can cause issues for other programs and processes. These conflicts can prevent applications such as iTunes and QuickTime Player from installing. See Using MSCONFIG to troubleshoot conflicts in Windows XP or Using MSCONFIG to troubleshoot conflicts in Windows Vista and Windows 7 for assistance disabling conflicting processes.
Additionally, some third-party security software cannot be disabled using Selective Startup (MSConfig). Because of this, it may be necessary to temporarily manually disable such software while troubleshooting installation. For assistance in configuring or disabling your security software, please contact the manufacturer.
Make sure your folder names don't contain strange characters If the iTunes installer (iTunesSetup) is not responding or appears frozen after launching the installer then the folder where the installer is stored may contain unusual characters. If you notice that the iTunes installer or stored in a folder like this, either rename the folder or move the iTunes installer to another location such as the Desktop before launching.
More help If these steps don't help, you may be able to find a solution to your issue by searching the Microsoft support website.
If the above troubleshooting steps have not helped, proceed to the following steps Solutions to common installation errors Here are some common symptoms you may see when installing iTunes and QuickTime for Microsoft Windows. If you are experiencing one of these symptoms, try the suggested troubleshooting steps:
If you only need to install QuickTime, or if iTunes installs but QuickTime installation did not complete Try downloading and installing the standalone version of QuickTime from http://www.apple.com/quicktime/download/. Be sure you download the version that does not include iTunes.
8helpful
2answers
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
11helpful
2answers
My itunes does not start whwn i clicked on icon.
Here's some info that may help - picked up from other boards where similar problems reported.
First check to see if Quicktime works normally, iTunes will not work without it.
If Quicktime is OK, then use these troubleshooting articles: XP version http://support.apple.com/kb/TS1421 Vista version http://support.apple.com/kb/TS1717
Have you installed any of the following: ACE & K-Lite mega codecs package, QT alternative, Storm codec, WinAVI video converter, Mpcstar, (possibly starcodec pack, 3ivx)
If so uninstall them, they are know to cause problems with Quickitme. Then download the version of Quickime without iTunes: http://www.apple.com/quicktime/download/win.html Now Remove Quicktime using the method for Quicktime in this article (just Quicktime): XP http://support.apple.com/kb/HT1925 Vista http://support.apple.com/kb/HT1923 When you come to your C:\Windows\system32\ folder you can delete any file or folder with Quicktime in the name. Restart you computer Install the stand alone Quicktime and check if it starts. If it does you are in a position to find out if iTunes is OK.
If Quicktime is OK, do you get any error message when you try to start iTunes? If not, open your task manager after trying to start iTunes. Do you see iTunes.exe running on the processes tab. If there is no error and you see iTunes.exe running then iTunes is hanging and we need to look at a slightly different route.
Sometimes it is just a problem with the itunes database file when it won't open after an upgrade. Press and hold the shift key while trying to start itunes. Does it give you an option to choose or create a new library? http://docs.info.apple.com/article.html?path=iTunesWin/8.0/en/15502.html
Bonjour is a common cause of iTunes hanging at start up. i.e. silent launch failure with iTunes.exe running on the processes tab. You can uninstall bonjour if you don't need it. However it is required for sharing libraries and other things
You could also try uninstalling it, then downloading bonjour from Apple and installing it directly. http://support.apple.com/downloads/Bonjour_for_Windows
1helpful
2answers
Try to open itunes but no quicktime
u can download quick time player in the following website..
www.filehippo.com...
thank u!!!
When I tried t osest up in itunes store it said quicktime problem. I remived qicktime and itunes from programs as instructed. Ho wdo I get my ipod synced to itunes and store for downloads?
ok i think i know what you mean. i had the sme problem. first totally remove all quicktime and iTunes. then go back to apple.com and download iTunes. Quicktime should install with it. Or it should pop up saying if you want to.
1helpful
Problem downloading Itunes on Dell P.C.
try the following procedure.
first, head into your start> control panel >Add/Remove programs and uninstall your QuickTime. if it goes, good. if it doesn't, we'll just attend to it when we attend to itunes.
next, download and install the Windows Installer CleanUp utility. use it to clear any existing itunes and/or QuickTime installation configuration information from the PC.
Description of the Windows Installer CleanUp Utility
http://support.microsoft.com/kb/290301/ (Copy ans paste the link in internet explorer)
next, use the the following document as a guide for manual removal of leftover itunes and quicktime program files:
Removing iTunes and QuickTime for Windows
http://support.apple.com/kb/HT1925?viewlocale=en_US
now try to install itunes again. does it go through properly this time?
If not then also try installing latest windows installer software
(Sometimes an iTunes entry or QuickTime entry doesn't show up in cleanUp, in conjunction with a missing .msi message, if there's an older version of the Windows Installer on the PC.)
http://support.microsoft.com/kb/893803/
I cannot get my itunes to work.
Remove your quicktime
Remove your Itunes
Reinstall your itunes.
Regards,
dC
2answers
Problem with QuickTime
Uninstall Quicktime I've tried following the steps here, but I can't seem to uninstall my version of Quicktime. I have a quicktime folder in my program files, but it doesn't appear in my "add/delete programs" screen accessed through the control panel. I also can't simply delete the entire quicktime file as one of the files gives me the "access denied" error and won't let me delete it.
So how do I get rid of this Quicktime program so I can try reinstalling itunes?
OR TRY THIS
You can download the stand alone Quicktime Player installer at:
http://www.apple.com/quicktime/download/standalone.html
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
