We just bought a 55LH90 LG LED tv. Our directv remote used to control the tv but now it does not. How do I go about getting one remote to do the directv receiver and the tv?
hi Tammy.
this is all i could find. 4 & 5 Digit Universal Remote Control Codes For LG TVs
DirecTV (directv - direct tv) Remote Codes For LG TV: LG 5 Digit TV codes: 11423, 10178, 11178. ..
LG 5 Digit TV codes: 11423, 10178, 11178. PRESS IN THIS ORDER:
"Menu" - "Settings" - "Remote" - "Program Remote" - "TV"
Slide mode switch at top to "TV" - enter LG - press and hold "select" & "mute" buttons
Wait for light to blink 4 times
Enter 10178.
Follow instructions.
If volume does not work then repeat and enter code 11178. RCA universal remote codes for LG tv:
LG TV codes: 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097,
1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1149, 1171, 1205.
Hi ,
try swapping the screen with another one to just see if it is behaving the same, because some times the screen circuitry or the led screen could be damaged .
Some TVs has the manual control to menu down right, on frame. Did you check?
Else, only way is to get a GOOD universal remote. The one used for DirecTV has a control of SOURCE.
2. Locate the 5-digit code for your TV (see pages 13-16). 3. Move the slide switch to TV. 4. Press and hold in the MUTE and SELECT keys at the same time until the green light under the TV icon flashes twice and then release both keys. 5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly the green light under TV will flash twice. 6. Aim the remote at your TV and press the power key once. The DIRECTV Receiver should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Sorry it took so long to answer you question about the remote codes for your LG television. You can use this link to go to the Direct TV customer support web page for remote control codes ( http://2getdtv.com/directv/tv_codes.html) You will find the codes listed under LG on the list. I hope this information helps you with the remote control code problems with you LG television. Thank you for using FixYa and have a nice day!
