How do I program my system to ring incoming calls on all extensions?
We have a small office and the receptionist is not in all the time. I need to have incoming calls ringing on all extensions, so that anyone can answer the phone.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Testimonial: "Great! Very specific and easy to follow instructions. Thanks for your fast response. RO"
I have gone through these steps to try and program my phone to answer the line when I pick up my handset. I am getting stuck. The 5th instruction from the bottom: "The display should say line 001: appear only" my phone says line 001: BlocA, and there is no "change" option. Any info on this problem is greatly appreciated! Thank you!!!
That sounds like your system is using a T-1 or a PRI for the lines.In this case, you'll need to know which line is ringing on the receptionists phone that you want to ring on yours. You can use the button inquiry feature (feature*0) on the receptionists set and press the line that you want to ring on your set, there will be a number (like L157) before the line name. This is the number you can use to program the lines appear and ring status in step 7(The display ask for a line number. press list).
