Sony XS-L1230 Car Speaker Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Box for sub open or not ? and how liter ? - Sony XS-L1230 Car Speaker
Anonymous
Level 3:
President:
  • Master 1,126 Answers
  • Posted on Nov 03, 2009
Anonymous
Master
Level 3:
President:
Answers
1126
Questions
0
Helped
563494
Points
3418
Look on page 2 under Thiele/Small parameters. Recommended 'Sealed' Box net volume 28 liter ( 1.0 cu. ft. )
http://www.docs.sony.com/release/XSL1230_es.pdf
1helpful
How can I install a speaker/sub into the backseat of my 1993 gmc sierra?
nt Best choice to go with would be 1 or more shallow mount 10" or 12" depending on sound. 6" deep box to bound to bottom of seat.
If use of 10" subs use hole 15" of width provieded off set your subs 3" up from the center of box allowing 3+ " for a lengh size slot port (allowing for more air and clearer sound since it under the seat) this will also allow you to lay seat down and get full use.
tip
Box specs and airspace for 8 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
on May 29, 2011 • Car Audio & Video
tip
Box specs and airpsace for 12 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 27 liters, meaning that you will end up with a box of 13 inches high, x 13 inches wide, x 13 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
Need to know airspace required for this sub
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 13 inches x 13 inches x 13 inches
What is the best enclosure volume for 15" Juggernaut 2000watts rms car subwoofer. i want to know the dimension of the box along with ports size.
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require.
On a 15 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
tip
Box size and airspace for 10 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 10 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 26 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. <br />Enjoy! <br />
1helpful
How much air space do boss blade 15 need
Enjoy!
I have found a Oz Audio Vector Power 15 but this is all I can find on this beast: http://www.carreview.com/mfr/oz-audio/subwoofers/PRD_173701_1808crx.aspx I need numbers to formulate a box and to determine...
On the amplifier side, I will need the wattage, and frequency of the speaker to tell you what amp you will need.
Enjoy!
1helpful
What are the specs on a kicker sub box for a challenger srt8
On a 8 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 11 liters, meaning that you will end up with a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 225mm high, x 225mm wide, x 225mm deep. Seal the box on the inside with silicone for better bass.
3helpful
Need dimensions for 12' 450watt IMPP Subwoolfers for proper air space
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 200mm, depending on the frequency of bass you require.
On a 12 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
