HP cp1700 Color Inkjet Printer Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp cp1700 printer 'squeeks' when printing. Sounds like the rack is dry or the bushings are bad. can it be lubricated? with what ?
Sheldon Dedek
Level 3:
  • Master 912 Answers
  • Posted on Nov 02, 2009
Sheldon Dedek
Master
Level 3:
Answers
912
Questions
0
Helped
306779
Points
3298
Be careful about where you put it, but I like to use a regular ordinary 3 in 1 machine oil. The rack itself is lubed with a form of grease, its composition is not known. I have used the oil everywhere else.
I don't put much into the printer when they start having issues, as it is cheaper (usually) to replace them. Interesting society that we live in now.
3answers
My HP CP1700 prints out gray tones in pink.
Your head / nozzles must be dirty , perform a nozzlecheck /head clean from printer software maintainance utility,
regards
3helpful
Sumsung 600CLP Lazer Jet printer has a squeeking
I assume the printer is at least a couple years old or it has been used extensively.
The squeaking could be caused by some normal wear and tear of the printer. If you feel daring enough, you'll need to remove the side covers of the printer and locate the gears connected to a shaft on one side of the printer. Each shaft goes to the opposite side of the printer, where it ends in a bushing. The bushings wear out and start to squeak. You can lubricate the bushings with a very small amount of white lithium grease, taking care not to put any grease on the roller.
Printer is squeeking when it prints pages - does
New Toner Cartridge stop usung Copy, use HP
1helpful
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
[email protected] (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Constant squeeking while drying clothes
It's most likely the roller bushigs/axles which need lubricating -- they've probably not failed yet, but will if ignored.
They squeak more when clothes are wet because of more weight.
I'd also lubricate the motor while your in there.
May 08, 2009 • Dryers
HP CP1700 - no cyan or blue printing
Try taking a look at your printheads. Have they been installed for some time. You may need to change them. Start with the Cyan first.
Inkworks
866-381-0541
HP cp1700 printer display panel blurred
is it the print coming out ok or blorred go to hp website and download drivers and software plus contact them for assistance on your printer. hope this has helped
k24674
Grand Canyon Tech
Grand Canyon Tech
