Panasonic DP-8020P wrote
Status: "Machine Maintenance count reached"
Message: "Periodic Maintenance required".
Can I reset it with service code? Or it's better to bring my copier to service provider for changing drum, developer, etc?
Yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
To select the Service Mode:
The service mode is selected when “FUNCTION”, “ORIGINAL SIZE”, and “3” keys are sequentially
pressed, then F1 will appear in the display.
F7 Mode: Electronic Counter:
Set the machine to Service Mode, and press "7" key on the Keypad.
Press the "START" key.
Enter the desired code number, or press “V”, ”/\” arrow keys.
If you wish to select another code number, scroll the menu with the arrow keys.
Press the "SET" key.
Enter the desired function code number, and press “SET” key.
is this helpful enough? :)
Hi do you know the service code for a Copystar all in one cs-2050 i replaced drum need to reset unit counter...help~
Where is "f7-03"?
Where can I find "f7-03"?
