Tricity Bendix TM310W Electric Dryer Logo
Posted on Jan 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryers hi there i mailed you earlier on and i gave wrong model it is a tricity bendix tm310w tumble dryer and the full tank light wont go off when you switch it on it sounds like it is fulling up thanks d fraser
Timon Gr?nlund
Level 2:
  • Expert 126 Answers
  • Posted on Jan 30, 2008
Timon Gr?nlund
Expert
Level 2:
Answers
126
Questions
0
Helped
57450
Points
165
I think the pump is full of lint, and is not able to pumpe the water from the bottom container to the container in the panel. Check that;)
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
3helpful
Motor working blowing hot but not turning
belt is broken: here is a website that will assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
THe drum is not reversing, please help
Tumble dryer running but not heating up its a tricity bendix tm 545
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Tumble dryer blowing cold
hi,
This is due to falty thermstat or heating element.
Very hot at back, making humming noise, but drum isn't spinning.
the drive belt is likely broken
belt replacements for most models are simple and cheap
have no experience of bendix cannot give exact instructions
TUMBLE DRYER
Hi, It wont fill up when the full tank light is on because it thinks the tank is full. Remove the tank and feel down inside where the tank sits into the machine. You should feel the switch, it sounds like it is stuck down.
Top Tricity Bendix Dryers Experts
john h
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
