Shoprider Sprinter Jumbo 3 Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shoprider scooter what it does is that runs for about 1hr. or 11/2 and make a sudden stop and started beeping and it doesn't move. I turn off the key and wait for about 1 min. and turn on the key and start it working again but after that the battery power run up quickly for example one bar less from fully charge it works for about 10 min. and lost the battery power completely. My batteries are 3 months old and are 55 miles. and I took my batteries to check and they are good. My charger works well. So what else can it be.
Rob Hill
Level 3:
  • Shoprider Master 1,480 Answers
  • Posted on Nov 17, 2014
Rob Hill
Shoprider Master
Level 3:
Answers
1480
Questions
0
Helped
517694
Points
3838
Hi, if you're really sure about the batteries , stating looking at the connections from the batteries to the controller, Black box located on the rear,,, now a simple test , move the lever to go forward gently not full speed how long does it last before stopping ...
I offer free controller testing ...
Regards
Rob
www.gewizrepairs.co.uk
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
5237
Points
34
I have the same problem with my pride hurricane ,
i am looking into the throttle potentiometer to see if that is the
problem,
i will post on here if i find out,
let me know how you get on !
  • Rob Hill
    Rob Hill Nov 17, 2014
    it can be the throttle so the trick is to move it in the upwards or downwards direction to see whether it prevents this, if the controller sees a big jump in resistance it will stop
Shoprider Mobility Scooter. My chair is a shoprider. I ran into 12 pack of soda and the scooter wrench is blinking and the lights across the top are blinking.
You can try pressing the reset button, or disconnect the battery for 10 minutes.
Shoprider Scooter User Manual
Eden Healthcare Solutions https://www.edenhcs.com.au > files > Shoprider... PDF If your scooter does unexpectedly stop then turn the key off, Wait for a few seconds and turn the key back on.
26 pages
Push the reset button. If the Powerchair / Scooter still doesn't turn on, check the condition of the batteries and the battery fuses located in-line with the battery cables. Under the seat and shroud are the batteries.
FAQ - SHOPRIDER Mobility Products
Shoprider https://shoprider.com > about > faq
Shoprider scooter new batteries turn on key it just beep beep
hi Delores, what shoprider model is it ?
Have you checked that the freewheel lever , if you can push the scooter , you need to move the freewheel lever , try again.
Regards
Rob
1helpful
Shoprider Echo 3 wheel mobility scooter-will not move. When key is turned on, there is just a continuous beeping. Battery is completely charged
Have the battery load tested because the symptoms are for a dead low battery. Just because it shows charged doesn't mean it is any good.
I have a shoprider echo when I turn it on the power meter works. The horn works. But there is a beep every 3 seconds. Please help
Your Throttle maybe out of neutral when you start the scooter.
Make sure your parking brake lever is on so the scooter is hard to move. If it is easy then it is not on and won't drive. Make sure there are not any cables that are disconnected to the motor and brake. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
2answers
My shoprider scooter is not moving it justkeeps beeping and, the sound seems to come from the back its not moving at all thanks
http://www.manualslib.com/manual/152236/Shoprider-Start-8-Gk9.html I hope this is your model. If not just google Shoprider scooter manuals.
2helpful
2answers
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Beeper code
Needs manufacturers key fob swiping over control
2helpful
My shoprider dasher just beeps
we just bought a shoprider monaco,after i cleaned it it did same thing just kept beeping,i found moving the free wheeling lever under back bumper a few times cleared it.Lever makes contact with a micro switch,on motor.
Hope this helps
Top Shoprider Health & Beauty Experts
Rob Hill
Rob Hill
NOEL
NOEL
jws1013
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
