Can you get into safe mode? When you're starting the system, you should see a Dell screen. As soon as that screen disappears start tapping on the F9 key until you see a Windows menu. From that menu - can you select either "last known good configuration" or Safe mode? If you can get into safe mode or "last known good configuration" then it sounds like you're working with an Operating System issue. If you cannot get into either of these - you're either looking at a serious Operating System problem or a hardware issue.Can you get into safe mode? When you're starting the system, you should see a Dell screen. As soon as that screen disappears start tapping on the F9 key until you see a Windows menu. From that menu - can you select either "last known good configuration" or Safe mode? If you can get into safe mode or "last known good configuration" then it sounds like you're working with an Operating System issue. If you cannot get into either of these - you're either looking at a serious Operating System problem or a hardware issue.
You can't post conmments that contain an email address.
you either do not have a harddrive connected to the computer or the harddrive you have in your computer went bad replace your harddrive and reload the operating system
Restart your system. As soon as the computer reboots and when you see the blue line on top of the screen with a label www.dell.com that the time that you have to hit ctrl+F11. Once Dell PC Restore appears click on the restore button.
Well its impossible to restore any of todays laptops without their factory os dvd/cd. You could setup new operative system and make your laptop simmilar to what it was on factory settings, or you can search dell to send you that same cd/dvd on your post mail to your house.
I suggest you read http://www.dell.com/ and contact them in order to solve your problem. Hope i helped you! =)
I assume you mean factory installation. You need the disks. Unless there is a recovery partition, unlikely on this model. Alternatively you could find an oem windows xp home or professional depending on what coa sticker is on the laptop and install that.
You operating system is corrupted meaning that your harddrive has failed or you got a bad virus. Only fix is having the operating system reinstalled and mostly likely that data is lost. Sorry to have to break the news to you and hope that you can get this resolved.
Apparently your model of laptop doesn't have a recovery partition. You're going to have to get out the Dell Operating System CD for your laptop, boot to the CD and reinstall Windows the old fashioned way. Make sure the product key on the laptop case is handy.
This might be because of corrupt OS(Operating Software) files. About the system password, you can reset it there's a boot cd called winternals burn it to a cd and boot from it. there's a tool called locksmith . use that to reset your admin password, or any password u want.
