When you try to set up the router using the set up Disc, sometimes you will get this error 322. This error says that there is hardwired connection between the router and the computer. Even if you connect the cable between the router and the computer , you will get this error message.
You can try to set up the router manually. It is easy.
Click Here for step by step solution
