If both bubble tubes has stopped working on one side then the problem is more likely to be a power issue. Somehow the power is not getting to the tube heaters. On the Wurlitzer OMT there is a small module on the inside of the main door that distributes the power to the various bubble tubes and the page turner (CD models). If the plug is loose or the wire is broken then that could cause one side to be off.
Hi Bob,
More than likely the bubble tube will need replacing.
I would check that the wiring to the tube is ok and that the tube is still full of the oil.
If you need a replacement try at www.victoryglass.com
Regards
Alan Hood
ami-man
UK
