Whirlpool Calypso GVW9959K Top Load Washer Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Whirlpool Calypso GVW9959K flashes ob, sl, and ld. now i figurd out that the drain pump was bad but should i buy a replacement or will it still flash ob and sl if i do?
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 21, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033304
Points
35540
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Code SL or 5L?
It is Code SL which means Suds Lock. Either you have too much soap suds for it to drain properly or Your drain pump is clogged and not spinning properly. Try running it through a rinse and spin cycle and if you still get a code (SL or Ld) then you will probably need to replace your drain pump.
1helpful
My calypso washer keeps stoppng and it comes up with the code LD, OB, 5L i'm not sure how to fix it.
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
2answers
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
1helpful
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
1helpful
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
OB:
If the motor controller detects an unrecoverable off-balance condition, the machine controller
will shut down and display an “ob” for off balance.
The lid switch must be opened at least once before restarting the cycle, if this condition
occurs. Opening the lid will allow the customer to view and redistribute the load.
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
1helpful
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
